pushrod length
  • Thread starter Thread starter tretz
  • Start date Start date Nov 4, 2006
T
tretz
62
stockton, ca
Nov 4, 2006
  • Nov 4, 2006
I installed windsor jr heads on my 68 302, checked pushrod length and the wear pattern says they are too short (off center towards intake side) again! Checked stock length first, too short, then tried another set at 6.905 length and still to short. Next step is a length checking pushrod. Anyone else have this much trouble?
edelbrock cam
crane roller rockers
68converted
772
Colorado
Nov 4, 2006
  • Nov 4, 2006
yup, me too. should have just bought the adjustable one to make the correct measurement the first time.
ashford
485
fargo ND
Nov 5, 2006
  • Nov 5, 2006
you dont happen to have this p/n 11746-16 do you? if so those are just generic 1.6 rockers to fit anything but have the geometry for a chevy. i know this because i bought them, and look em up for a chevy and you get the same p/n. the distance from tip to fulcrum centers is shorter on chevy than on a ford, and being so they will never quite hit the center of the stem tip.
T
tretz
62
stockton, ca
Nov 5, 2006
  • Nov 5, 2006
yes that is the part no. that I have, where do I go from here???
T
tretz
62
stockton, ca
Nov 6, 2006
  • Nov 6, 2006
bump
SoCalCruising
2,437
SoCal
Nov 7, 2006
  • Nov 7, 2006
I had not heard that about the Crane rockers - not that it's wrong. Go to www.mif-lift.com to be schooled on how to set up rockers and determine proper pushrod length. If you still have a poor wear pattern, you'll have to swap rockers.
T
tretz
62
stockton, ca
Nov 7, 2006
  • Nov 7, 2006
I do understand how to determine pushrod length thats not my problem, my gripe is that it looks to me that I would need a pushrod by at least .250 longer than stock to get where I want to be, that seems like a lot. What about those who bolted these on without checking?
I called cranes tech line today an they say they are not aware of any issues with these rocker and the small block chevy and ford rockers are interchangable.They also said the windsor jr heads are most likely the source of my problems????
I'm going to match one up to a frpp or comp cams rocker and see what I find.
T
tretz
62
stockton, ca
Nov 11, 2006
  • Nov 11, 2006
I'ved solved my pushrod problem. Went to mustangs plus and purchased some ford racing roller rockers took them home and matched them up to the crane energizer rocker and there was a difference of about 3/32" in length from the pivot point to the roller tip, the ford rocker being longer. Installed it on the engine and now the contact pattern on the valve stem is perfectly centered. This is with the ford racing pushrods. I guess I'll call crane again and ask them to explain this since I understand they supply ford with these rockers
classic boost
709
canton, oh
Nov 12, 2006
  • Nov 12, 2006
if your geometery is set up right (mid-lift), then it doesn't matter as much if the wear pattern is off center, as long as it's not off by a mile.
T
tretz
62
stockton, ca
Nov 12, 2006
#10
  • Nov 12, 2006
  • #10
yeah, but I've got a lot of time and money tied up in this engine and I don't want to have it in the back of my mind that I could have done a better job of assembly. Maybe when I was younger I would have let it go as close enough but not now.
T
408w pushrods
  • Towegage
  • Sep 19, 2025
  • Fox Engine Swaparoo
Fox Engine Swaparoo Sep 19, 2025
M
Pushrod length
  • mattcrp1
  • Sep 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 4, 2025
mattcrp1
M
G
Engine Pushrod Length Question
  • germain101
  • Sep 22, 2025
Fox 5.0 Mustang Tech Sep 25, 2025
Engine Finishing up 331 build
  • RedFury5.0
  • Mar 21, 2025
Fox 5.0 Mustang Tech Apr 20, 2025
RedFury5.0
Engine Pushrod Length?
  • foxbodyclark
  • Jan 25, 2025
Fox 5.0 Mustang Tech Jan 25, 2025
limp
