Pushrods issues
  • Thread starter Thread starter mustangfan1990
  • Start date Start date Mar 26, 2008
mustangfan1990
505
Lenoir, North Carolina
Mar 26, 2008
  • Mar 26, 2008
Ok I have had this problem for a while now but I never really posted it because it happened few and far between but now since i got my car tuned it has happpened twice in 2 days. I keep breaking rocker arm studs. I was told by boosted performance that my pushrods was the wrong legnth. Now how do I get the right legnth? I know they make something that looks like a pushrod that you can screw to find out but i dont understand how you measure it with the rocker arm on there. You would have to have the rockerarm adjusted to have the right legnth right? Well how do you adjust the rockerarms without a pushrod lol
P
PJC Racing
199
  • Mar 26, 2008
Here you go: http://www.compcams.com/Technical/FAQ/ValvetrainGeometry.asp
BK_CAULEY
it's built for speed not longevity, woman
Dec 26, 2006
49
Thomasville, ga
Mar 26, 2008
  • Mar 26, 2008
here is one of my threads where i went throug hsome of the same stuff. hope it helps as well.
http://forums.stangnet.com/showthread.php?t=728761
347HO
462
Seattle
Mar 26, 2008
  • Mar 26, 2008
I don't see how the wrong pushrod length will allow your engine to run properly if they are too long. If they were, in most cases... not yours evidently, the valves would never close.
If they are too short, well... then you'd have serious rocker tip to valve stem issues, and you'd see right away the strange angle of the rockers once you had them adjusted tension wise.
IMO you have spring issues, or install height issues. Another could be oiling. No or limited oiling can create funky problems up top.
5.0Droptop
...all those nights we shared, and you're a dude??
Special Agent Mukity-Muck Whats in Charge Round Here
May 15, 2002
1,785
1,130
233
Indiana
Mar 26, 2008
  • Mar 26, 2008
I broke a couple of rocker studs on my 347 and one on my 306. I never did figgure out why it happened.
G
Engine Pushrod Length Question
  • germain101
  • Sep 22, 2025
Fox 5.0 Mustang Tech Sep 25, 2025
T
408w pushrods
  • Towegage
  • Sep 19, 2025
  • Fox Engine Swaparoo
Fox Engine Swaparoo Sep 19, 2025
Engine Pushrod Length?
  • foxbodyclark
  • Jan 25, 2025
Fox 5.0 Mustang Tech Jan 25, 2025
limp
Engine Are These rings OK?
  • PonyGTrider
  • Sep 21, 2026
Fox 5.0 Mustang Tech Sep 26, 2026
PonyGTrider
A
Valvetrain help
  • Angelq1028
  • Dec 20, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 21, 2024
limp
