Just installed some gtp heads on my 89 GT and have run into a little problem.
My valve train was making noise and i noticed that when the valves are closed that rocker arm does not touch the valve spring. So when it runs it its causing it to tap.(its loud) I reused my factory arms(solid non adjustable) and i hear factory gtp's come with rollers. do i need new rockers or is the push rod length different?
