Actually, I find installing the pedestal mounts correctly is more tedious than the stud mounts. For either, the cam has to be on the base circle for the pair you're installing (both valves closed). Put your socket on the crank pulley and rotate the engine clockwise until the exhaust valve opens and closes. As it's closing the intake will start opening. Slowly rotate until the intake valve closes all the way -- you can now install/re-do your install on that pair. If you start with #1, and follow the firing order, you'll find the next pair in the order will require just a small amount of engine rotation before they're ready to do.
For stud or pedestal, once both valves are closed, slowly tighten the bolt or nut until there's zero lash - that is, the rocker won't rock by hand because there's no gap on the pushrod end or the valve stem end. For stud mount, from this point you simply tighten 1/2 to 3/4 of a turn, and then set the allen head lock and you're done.
To properly install the pedestal mounts you have to torque the bolt to 17-20 ft-lbs. while you are counting the number of turns it takes to get there. You should hit that torque somewhere between 1/4 and 1 turn. If it takes more than one turn to get there, you need to shim that rocker to raise it's height. One .030" shim will reduce the number of turns by about 1/4. Most people use shims to try and get all of theirs to hit the torque at about the same number of turns - around 1/2-3/4. On mine, 11 of them hit the torque without shimming at about 1/2 turn. 4 of them required a .030" shim to hit at 1/2 turn, and 1 required a .060" shim to hit at 1/2 turn. If your heads have been cut, or the block decked and shorter pushrods were not used, you may need shims on all of them. If it takes less than 1/4 turn to hit the torque, you're gonna need longer pusrods, or to remove some material from the bottom of that rocker's trunion. You'll know you have this problem if you find it's not possible to get to zero lash by hand, or you can't get zero lash even with it fully torqued. Good luck with it.
edit - Oh, I've also discovered that this works best (for both types) if the engine's warm. So do the best job you can with it cold, but know that after the first warm up, if one or two are making racket, you may have to go back when things are warm, and do it again. If you're lucky, you may be able to determine which rockers(s) are making the noise, and perform the installation procedure on just those. I've never been able to do that. Once they're correct, if for some reason you have to remove them, as long as none of the components affecting valve train dimension change, simply keep track of the shims and put them back the same way and you should be fine. I had mine quiet, did a cam change, and had to go back through the same procedure all over again - including re-checking them when warm to quiet down a couple of noisy ones. Mine run as quiet as it did when stock. (pedestal mount 1.7 rollers)
