Putting 275\40\17 all around... will this be fine? Rubbing?
Tombfyre
14
Anyone have this setup? I have 17x9 wheels (10th anniv) on my v6.. and the rims are getting stone chips all over the outer machined part where there should be rubber. (running 255x45x17 now).. so i am getting the sized tires that are supposed to be on these wheels. But I just want to make sure they won't rub at all or stick out past the top of the front fender.
:canada:
98V6 K.I.T.T. said:
no need to run a 275 in the front, not positive but you might rub in the front depending on suspension....255's should be fine, run a 275 out back.
255 leaves the outer rim of the 10th anniv wheels exposed... if you look from the side... wheel sticks out past the wall of the tire.
