Fox Wheel Spacer
wells1989
63
48
28
Indiana Pa
I have a 90 fox with 17x9 cobra r's 4 bolt. 275 40 r 17 tires on back. I have been running this setup for years. Occasionally i get a slight rub on the inner fender. Not really a concern though. I bought a set of 1/4" wheel spacers for the back. The purpose of these is strictly cosmetic because i think it looks better with the back tires setting out flush with the fender lips. Prior to installation i got 8.5 threads at torque. Now i get 5.5 threads at torque. Is this enough?
I understand that lug nuts do not support any load and that all the load and torque is handled by the proper clamping force.
If you have hubcentric spacers it should be enough. That focuses the clamping force into the hub. If you have the flat disc with holes drilled into them then you are putting all that stress onto the studs which will eventually fail. Maybe not with the wheel coming off, but you will have issues.
I could be wrong but i though a hub centric is only for that. Hub centering. No force is supported by the hub.
I disagree
Mustang Wheel Spacer Tech
Are wheel spacers safe?
Yes. When properly installed they are just as safe as wheels installed without spacers.
Will wheel spacers cause my wheel studs to bend?
No. The load from a wheel is transferred to the axle/hub through the friction of the clamped joint, not through the wheel stud. A wheel stud can only bend if the lug nuts are not properly torqued, in which case the wheel is about to fall off, anyway.
The Physics of Keeping the Wheels On
  • As long as the wheel, hub, and spacer are stiff enough to prevent flexing and loss of clamp force, the cause of most wheel stud failures is under tightened lug nuts (not enough clamping force) orover tightened lug nuts (the stud has been stretched past it's elastic limit, so the clamping force goes away). Therefore, properly installed wheel spacers are perfectly safe.
  • The wheel stud applies a clamping force that holds the wheel to the hub. When the lug nuts are tightened, the wheel studs stretch elastically, like very stiff springs. The lug nuts should be tightened until the stud is at 90% of its elastic limit. This will provide the greatest possible force to hold the wheel to the hub.
  • The amount of clamping force at a joint is important because of the coefficient of friction (Cf). The more clamping force applied to the joint (in this case the joint between the wheel and the hub), the more force required to make the wheel slip relative to the hub. Unless the wheel slips on the hub, there cannot be any bending load on the stud.
  • Coefficient of friction -- There is friction between the wheel face and hub face. This friction can be measured, and it is called the "coefficient of friction". The coefficient of friction (Cf) is the ratio of normal force, at the intersection of two surfaces, to the lateral force required to slip the bodies relative to one another. As an example, good street tires have a Cf of 0.9. This means that if there is a 100-pound vertical force applied to the tire, the tire can generate 90 lbs. of cornering force before it slides.
  • When the car starts moving, the stress applied to the stud does not change appreciably, unless one of two things happens:
    1. The vertical component of any external force applied to the wheel is so great that theclamping force is not sufficient to hold the wheel in place, and it slips on the hub. At this point the stud is loaded in bending and in shear, and may yield, or even break.
    2. Some portion of the clamped joint, wheel, or hub is not stiff enough to prevent flexing, and allows the tension load on the stud to drop to zero. With no tension load on the stud, the clamped joint is no longer tight. The wheel can then move relative to the hub, and place a bending load on the studs.
  • Inserting a wheel spacer between the hub and wheel changes nothing about these physics.
  • The hub center of a hubcentric spacer does not hold the spacer on the hub or reduce the chance of stud failure. There is never any load on the lip of the wheel spacer. For there to be a load on the lip, the friction force in the joint must have been completely overcome. The lip on a hubcentric wheel spacer serves only as an aid for wheel installation.
  • Increasing the length of the wheel studs to use a wider wheel spacer has no appreciable effect.
Please dont take this conversation as i am being a pain in the behind or that if i didnt want your opinion i should not have asked. I just want to know from those who have more experience than myself if my spacers are safe.
I am fine with someone who says no but for reasons other than those that you have given. This is simply a question of do i have enough threads or not. Also what is proper torque?
all a hubcentric spacer does is center the spacer and wheel onto the hub, which considering most of the factory cars from this era (and most aftermarket wheels) are LUG centric, isnt that big of a deal unless your using one of the big 1" spacers with its own lug studs. a 1/4" spacer would be (and is) fine.
the "safe" rule says that a nut needs 1x diameters of full thread engagement for full strength. mustang studs are 1/2"-20 threads, and therefore need a minimum of 1/2" of FULL thread engagement (10 turns). looks like you'll need longer studs.
Reactions: FoxMustangLvr
Thank you sir. I agree with everything you have stated but i have 1 question. I do not get 10 turns without the spacer. I spun my lugs on my stud 5.5 turns with no wheel on and i have 5/8 of stud buried in the lug?
is that including the "nose" of the stud? each turn on the nut would be 0.05", so 10 turns of engagement would be 0.500". the engineering/machining "rule of thumb" is usually to have 1.5x diameters or so of possible engagement, though its not always practical.
I agree with @Chuckman about proper minimum thread engagement being equal to the diameter of what you're working with however that gives you a Safety Factor of about ZERO (IMO) which I would NOT follow on my own vehicle. Regardless what you had before (8.5x turns) the 5.5x turns does not sit well with me. Get longer studs or run different wheels is what I advise.
