- Aug 11, 2001
- 178
- 0
- 0
Ok guys I've got two questions for you. This is what's going on with my car: I'll be installing a Vortech supercharger in the next few weeks along with a ported Cobra Intake (both upper -was cut and ported- and lower intakes) and a built C-6 trans with reverse pattern valve body and transbrake. The car has already the following parts: Thumper heads, 1.7 RR, 65mm TB, C&L 73mm MAF, Bassani complete exhaust system (headers, x pipe, cat back), Tweecer, 180* thermostat, 24 lbs injectors, fuel pressure regulator, 3.73 gears. The following parts will be removed because of the supercharger and intake build up: ported stock upper intake, Holley Systemax I lower, MAC Cold air (I may be selling them since I'll have no use for it)
Questions:
1) I was told to get a 3000 rpm torque converter because the car is my daily driver. Would that be ok or would you recomend a higher TQ converter?
2) I have an F-303 camshaft laying around. Should I put that cam along with the supercharger and intake?
Any help will be appreciated
Questions:
