Thanks, tons of info
Brad,
Yeah, when you think about it - rear housing, gears, coilovers, brakes, it's a pretty good deal because it rolls a few projects into one.
Great job on getting everything installed there, I'm impressed. It sounds like, without the fab skills, the tools, or the room to get it installed that I would be incurring some pretty heavy labor costs.
Believe it or not, that backspace issue might be a dealbreaker for me. I've already got my wheels and tires done (17x9, 5.5bs, coy's c-67 edelbrock copy) with a 275/40/17. If you're saying 4.5 or 4.75 bs is the most, looks like my project would be dead in the water.
I was going to go the composite springs route as another option - that, and a Maier new-style panhard rod kit. No need for the torque arm until I get to the engine. But then the cost of rear discs on top of that . . .
The last one, more for dialing in the "stance" and for ride and after I finally read a few ride impressions saying it handles well, would be the Air Ride Air Bar 4-link adjustable air shock system. But at $2k, and then on to rear brakes, still not a bargain, and there's nothing IRS about it . . . still, tire clearance would seem to be maximized and the adjustability would be pretty sweet. A narrower rear could be put on later, but since mount ears have to be welded on to the axle I would have to order up another set of mount ears later on, not a biggie.
Looks like this might turn into a general rear suspension thread . . .
Thanks for all the info, I hadn't heard/thought of the backspace issue,
Joe
mustbereel said:
Hi 70 Vert,
I am in the process of installing a Heidt's IRS in my 65 Fastback. I bought the IRS from Mustang Depot and have been following Reen's progress as inspiration. Although my car is far from complete I have learned much so far that I am happy to pass on.
This install is very fab heavy. There is nothing "bolt in" about it. Good fab and welding skills are a must. That being the case you can mount it in such a way to get just about any ride height you want. I notched and reinforced the rear subframe where the Heidt's IRS mounts to match the pinion angle to my TKO500. I modified my TCP subframe x brace to attach the forward struts. Even with many measurements taken I still managed to mount the IRS a little bit crooked requiring some rework.
I thought I would gain some clearance for larger tires by eliminating the leaf springs but the bracket for the foward struts limit the amount of backspacing you can use. I found that on a 17" rim the max bs is about 4.5-4.75". In retrospect I should have gone with one size smaller track width and used less backspacing to allow for more tire. As it is I am going to use 9.5" rims with 275/40/17 tires. I modified the outer wheel housings to give about 1.5" more space.
The only thing I haven't figured out yet is where to run the exhaust pipes. I want to run the pipes all the way out the back and between the various struts and crossmembers there isn't much room for pipes. There really isn't much room for side exiting exhaust either. I will probably find a place to route the pipe to the back and mount the mufflers beside the gas tank.
I don't know if there will be a significant improvement in ride and handling vs a solid alxe. My other choice was to go with composit springs, aluminum 9" housing and torque arm. Belive it or not the Heidt's IRS is significantly less money since it includes everything from hub to hub.
Wow, this was a long post. It's just I've been working on the car all morning and it is fresh in my mind.
Brad
