qa1 coil-over kit, adjustable ride height?
ProjectoStang
80
I was going to order the whole front suspension from qa1, but I am not sure if the coil- over kit is adjustable for ride height. I looked at the summit picture and it doesn't show the cover tube that you would use to adjust the height.
Does anyone know if the ride height is adjustable?
I have it in my acr, and it is adjustable, the entire shockbody is threaded, and aluminum, It saves a ton of weight and makes working on the car from underneath alot easier. There are some minor issues that I have had with the k-member, but nothing serious, or dangerous.
well, when installing the motor mounts I had a real problem getting them lined up. Nothing a prybar wouldnt solve. Also on my motor mounts (energy suspension) there was a locating tab next to the stud. It had to be ground off inorder for the mounts to work.
