I had just finished painting the car, and while I was waiting for some other parts to come in I decided to go ahead and put on my Tubular stuff and coil overs. Seeing as how I need new tires and an alignment anyway I didn't worry too much about it.
K-member was pretty straight forward, unbolt 8 bolts, lower out of way, bolt on new one making sure it's square yada yada.
A-arms too very easy to do. No real issues at all.
Come time to install the coilovers. I am using a set of H2003 Struts and 325lb 14" coils. I ran into the normal interference points with the brake lines so I bent and moved them out of the way, no issues with that. BUT I cannot make the darn thing any lower than a fresh off the factory floor Foxbody mustang. If I go too loose on the spring seat it doesn't make any difference. Its like either A) the spring rate is just too much for the vehicle, (where I don't see how that is since I see plenty of 400+ lb spring vehicles way lower than mine) or B) the arms are binding on something such as the swaybar, and not allowing them to compress correctly.
What do you guys think? Heres an image of roughly how it sat before and afterwards.
I went from a stock K-member/Control arm (with Gripp bushings and Steeda X2 balljoints) with BBK Progressive Coil, and KYB GR2 strut to the New setup mentioned above.
Before: (yes it's before the paint)
and after:
It does ride a WHOLE FRIGGIN lot smoother though I might add. Going Coilover is gonna save my kidneys.
and after:
