Quadrant help ASAP
  • Thread starter Thread starter slow88stang
  • Start date Start date Mar 31, 2004
slow88stang
144
St Albert AB
Mar 31, 2004
  • Mar 31, 2004
Im replacing my clutch quadrant with a new stock one. I got the big plastic gear off but i can not get the smaller ratcheting gear off for the life of me. What do I do? How can I get it off?
cevtv
1,113
Massachusetts
Mar 31, 2004
  • Mar 31, 2004
How come you went with a stock quadrant? Usually, when replacing the quadrant with an aftermarket one, everyone breaks the pawl to get it off.
slow88stang
144
St Albert AB
Mar 31, 2004
  • Mar 31, 2004
Please Someone help.....Right now im going back and forth from computer to car trying to figure it out.
djk8705
154
Fairfax, Va
Mar 31, 2004
  • Mar 31, 2004
never replaced one but when i was taking out the lil piece of plastic i had to remove the carpet and push the pedal to the metal b4 i cud get it to come off the top.... try that cuz i spent 10minutes with it pused up against the carpet tryin to get it off...
-Dan
p.s.- get the steeda one ..hah
slow88stang
144
St Albert AB
Mar 31, 2004
  • Mar 31, 2004
I had to go with a stock one because that is all i could get in this stupid town im in. I would have liked to get an adjustable but i needed one right away and ford dealers were the only people that knew what a quadrant was.
cevtv
1,113
Massachusetts
Mar 31, 2004
  • Mar 31, 2004
Ahh, ok...makes sense. Like I said, I had to break mine. Good luck.
slow88stang
144
St Albert AB
Mar 31, 2004
  • Mar 31, 2004
I have the whole new everything so I dont really care if it breaks I cant even get mine to break. Where did yours break at? maybe its a weak point. And how did you break it?
slow88stang
144
St Albert AB
Mar 31, 2004
  • Mar 31, 2004
I found the problem....the spring is holding it on. But there is no possible way for me to get in there enough to move the spring. what should i do
cevtv
1,113
Massachusetts
Mar 31, 2004
  • Mar 31, 2004
I pried on it with a screwdriver until it snapped.
88LX
327
Chicago, IL
Mar 31, 2004
#10
  • Mar 31, 2004
  • #10
try getting at it from the hole in the fire wall that the cable goes through. use a long screwdriver.
Notchbck93
422
IL
Mar 31, 2004
#11
  • Mar 31, 2004
  • #11
Dude, just pull out the column and drop down the pedal assemble and do it the right way. That is the only way to replace the "stock part" If you went with an aftermarket you wouldn't have to do that!
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
00 4.6L V8 new clutch won’t go into gear when on?
  • Timboslice
  • Aug 15, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 21, 2026
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
