v8only said:NO heavy throttle at take off or cruising for 500 miles. break her in for 500 miles, and lots of highway miles don't count, stop and go is what you want.
a little late on the quadrant issue, but the ford racing quadrant is fine, except that it's too long and can only be used with the adj cables, which are junk and prone to stretching and snapping. If this happens to you, I'd suggest picking up a single hook quadrant such as the mm or fiore quadrant. (you don't need a multiple hook quadrant). as for the firewall adjuster, there is no better piece than the fiore unit. I prefer the fwa because you don't have to crawl on your back to adj the clutch.
Thanks for the advice, i got the frpp adjustable cable and by looking at it, it is exactly the same in length and thickness as the stock cable. but ur right i probably should have gone with a mm or fiore quadrant. i just didn't have enough time to wait for the parts to get here etc. i can't wait till its all borken in so i can truly feel what a new clutch is like.
