Quality Clutch Quadrant?
  • Thread starter Thread starter Fuzion
  • Start date Start date Nov 10, 2006
First Prev 2 of 2
Fuzion
81
Virginia
Nov 13, 2006
#21
  • Nov 13, 2006
  • #21
v8only said:
NO heavy throttle at take off or cruising for 500 miles. break her in for 500 miles, and lots of highway miles don't count, stop and go is what you want.
a little late on the quadrant issue, but the ford racing quadrant is fine, except that it's too long and can only be used with the adj cables, which are junk and prone to stretching and snapping. If this happens to you, I'd suggest picking up a single hook quadrant such as the mm or fiore quadrant. (you don't need a multiple hook quadrant). as for the firewall adjuster, there is no better piece than the fiore unit. I prefer the fwa because you don't have to crawl on your back to adj the clutch.
Thanks for the advice, i got the frpp adjustable cable and by looking at it, it is exactly the same in length and thickness as the stock cable. but ur right i probably should have gone with a mm or fiore quadrant. i just didn't have enough time to wait for the parts to get here etc. i can't wait till its all borken in so i can truly feel what a new clutch is like.
HISSIN50
34
129
Nov 13, 2006
#22
  • Nov 13, 2006
  • #22
Was your stocker all stretched out beyond belief? I did the same comparo and the stocker was markedly shorter than the FRPP cable. I also noted the FRPP cable was not quite as robust, and I think there was one little tiny layer of sheathing inside the OEM cable that was missing on my particular FRPP cable.
I liked the FRPP cable a bit better than Jeremy did (I actually thought it did decently well for me) and what I know of adjustable cables, it's about as good as anything out there IMHO, but it's still not quite as good as the OEM unit.
Just MHO and random thoughts.
V
v8only
2,378
22
49
Nov 13, 2006
#23
  • Nov 13, 2006
  • #23
truth be told, my hatred toward adj cables was due to snapping 3 of them within a couple of months, however I found out after 3 cables it was due to misrouting of the cable which was my primary problem, this was years ago and I haven't tried another adj cable yet, however I like the benefit of having a longer cable, as it really throws in extra adjustability in extreme different situations (like my buddies car that I worked on this weekend)
8950HO
658
#24
  • Nov 13, 2006
  • #24
I`ve read the adjustable cables suck,but someone on corral mentioned that Hay`s makes one for 5.0L stangs that`s apparently heavy duty and well built.
Might want to take a look at the Hay`s cable if you have problems with other adjustable cables or can`t run the OEM cable.
First Prev 2 of 2
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
Drivetrain Time to pull and lube the clutch cable
  • LX Dave
  • Dec 21, 2024
2K
Fox 5.0 Mustang Tech Jan 7, 2025
limp
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
Need a clutch, 1982 Capri RS 5.0 owner, am I allowed to participate?
  • scudzuki
  • Apr 4, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 7, 2025
