Question About 351 Heads
  • Thread starter Thread starter dr hook
  • Start date Start date Mar 29, 2017
D
dr hook
47
71
28
Mar 29, 2017
  • Mar 29, 2017
So through some bartering I've been slowly collecting some parts. I got a bunch of stuff from a buddy of mine, which included a set of heads. He told me that they were "Really well ported/polished E7 heads. Good valve job, double valve springs". I didnt even look them over as I loaded them up. Turns out... they are 351 heads. The numbers are D80E.
Things I have waiting to go on the car:
Ported GT40 intake
TrickFlow Stage1 cam
65mm tb
SO, from what I've found... these heads will make less power on my little stock 302 because of the larger combustion chambers. So basically I have no use for these. Is that correct?
D
Dart68
87
22
18
Mar 29, 2017
  • Mar 29, 2017
Ported GT40 intake
65mm tb
The effect on power output will depend on how much lower your CR is compared to the 302 heads. You may find the difference is actually minimal. What's more important is flow characteristics. Notice I said flow characteristics and not max flow. The area "under the curve" at a targeted RPM is more important than max flow at max RPM. In the end if you're willing to spend the money there are better heads available.
rd
3,316
63
109
Ocean Springs MS
Apr 3, 2017
  • Apr 3, 2017
I think D80E heads are the common 70s stock heads, and are the same casting as 302 heads except 351s have have larger (1/2 in) head bolt holes. Iirc all of them have 70 cc chambers and 1.78 intakes and 1.48 exhaust valve sizes. I ported a set once a long time ago, and they did pick up a couple tenths over an unported set of the same. They were the stock head on my 79 5.0 Capri, 140 hp two barrel. However, these days there much better stock style heads, Gt40s, p heads, etc. You may find that by the time you spend money do a valve job and install decent springs, you are in the same price range as much better ones.
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Thursday at 9:34 PM
Qtrhrse23
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
Engine Forged flat top pistons from 5.0 fit a 351 build?
  • PonyGTrider
  • May 22, 2025
Fox 5.0 Mustang Tech Feb 1, 2026
PonyGTrider
9
Milton Questions, 351 swap newedge
  • 996stang
  • Jul 20, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 25, 2026
Killer351w
K
I
Engine What Aluminum Heads???
  • Iceman1998
  • Sep 8, 2024
2K
Fox 5.0 Mustang Tech Sep 15, 2024
