question about big bore set-ups
Tony01GT said:
Is a Big Bore a 5.4 block bored and stroked? Would a 5.4 fit with no problems? and would things like my headers, intake, and heads fit?
The 4.6 and 5.4 share bore size and cylinder spacing. Only the stroke and deck height differ. The 4.6 has a 3.543" stroke while the 5.4 has a 4.165" stroke. Both share the 3.552" bore.
I think the biggest you can go on a mod is a 3.7" bore if you use sleeves.
The 5.4 is a taller, wider engine than the 4.6 and isn't a drop in into the engine bay of a Mustang; it'll fit but it'll take some work to sort out. The intake ports are a bit further apart so you'd need a 5.4-specific intake manifold. The heads will fit but the headers will start a bit higher up and will thus end up a bit higher up (that is, nearer the floor)... There may be clearance issues at the sides because of the extra width and height.
