  • SN95 4.6L Mustang Tech
question about cams!
  • Thread starter Thread starter VPStang
  • Start date Start date Dec 1, 2005
VPStang
346
bHAM, alabama
Dec 1, 2005
  • Dec 1, 2005
what is the difference between blower cams, stage I, stage II?
Is it unsafe or not feasible to have a blower with a cam besides blower cams?
I've read that cams for mod motor really come alive at 3500 rpm+..so wouldn't that compliment a centri perfectly?
I have no knowledge what so ever about cams, so I hope you guys can bare with the vage questions and ignorance....
thanks..
Turbo92PGT
746
Auburn Washington
Dec 2, 2005
  • Dec 2, 2005
I may be wrong but from my understanding you DO NOT want an NA cam on a supercharged car, because of the valves being open at the same time, you wont make much power because of this.
If you think you are going to go with a blower at some time, then get a blower cam, unless you dont mind swapping cams again.
Stage 1's are meant for a more stock car (small bolt ons) and doesn't normally require a tune, cept for best performance. Not as much lope as a stage 2 but the numbers arent as good either.
Stage 2's usually require a lower gear to keep them in their powerband, and sometimes low end power/torque is lost, but it makes up for it in the higher RPMS.
I went with crower stage 2's and am pretty happy but the lope is lame. Doesnt make much noise at all. If its just COLD OUT and i floor it in third say gettin on the freeway, it'll pull and then when it hits 4k the tires break loose. lol
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Los Angeles, California
Dec 2, 2005
  • Dec 2, 2005
you pretty much got it down on the stg 1 and 2 for N/A. I dont know alot about those stages in a blower cam but they do have a different grind for them that works better with the blower but it is true most cams come alive at around 3000rpm
M
MatthewP
355
Calgary, Alberta
Dec 2, 2005
  • Dec 2, 2005
Forced induction works better with a larger lobe center angle and less overlap - the positive inlet pressure blows a portion of the charge right through to the exhaust during the overlap period. N/A setups normally work better with more overlap and a tighter lobe center angle as this aids in scavenging.
As far as "stage 1" and "stage 2" cams are concerned, you should ignore this monikers and look instead at the actual cam specs. You will find that some cam maker's "stage 1" cam is as aggressive as other cam maker's "stage 3" cam. Look at the duration at .050", and the lift to get a real comparison.
-Matthew
VPStang
346
bHAM, alabama
Dec 5, 2005
  • Dec 5, 2005
bump
K
kyles03sonicgt
111
Berkley, Michigan
Dec 6, 2005
  • Dec 6, 2005
I'm looking to put VT cams into my 03 gt this spring. I'm looking for the mean idle sound and the power that come with a good set of cams. I am torn between VT stage 1's and VT stage 2's. The car is a daily driver, would stage 2's be too much? Will I not get the sound at idle with stage 1's? Thanks guys
streetstang03
unModerator
Dec 27, 2003
the dark side of the moon/home of the 1999, 2003,
Dec 6, 2005
  • Dec 6, 2005
stage IIs wont be too much for a DD. if u have to worry about emissions, go for stage Is.
remember, w/ stage II cams, you also need to get new valve springs, so thats another $180 added to the cost.
BooWFO
991
Louisville, KY
Dec 7, 2005
  • Dec 7, 2005
Like streetstang said Stg 2's you need new springs. If you are taking it somewhere to do the install. I've been told it drives the cost WAY up. I was also told to get the full benefit of stg 2's you need ported heads. So yet again more $$.
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
Gt40 e303 combo questions
  • 99mustanggt2018
  • Mar 30, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Mar 30, 2025
KRUISR
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
P
New member with 98
  • Poster
  • Apr 28, 2025
1996 - 2004 SN95 Mustang -General/Talk- May 8, 2025
Poster
P
