  • 1994 - 1995 Specific Tech
Question about motor mounts...
  • Thread starter Thread starter KingDiamond
  • Start date Start date Apr 1, 2005
KingDiamond
637
Chicago, IL
Apr 1, 2005
  • Apr 1, 2005
My mustang has 106,000 miles, and I'm doing the trans swap and when I took the trans off the engine shakes a lot of it move it with your hand. Is that normal? Also if I don't keep the back end of the tranny jacked up (with the crossmember removed) the engine and tranny tilt back a lot at a steep angle. Could this mean that the motor mounts are bad? I looked at them and they don't look torn up, cracked, or anything bad.
baglock1
The Bartender
6,612
Space Coast, FL
Apr 1, 2005
  • Apr 1, 2005
No, it just means that there's a lot of stress on them when you do that. If you romove the crossmember and just let the tranny fall, it'd probably tear the motor mounts completely out. That rubber just isn't srong enough to hold the entire motor in place with the tranny acting like a boat anchor on it. Consider the leverage at work.
KingDiamond
637
Chicago, IL
Apr 1, 2005
  • Apr 1, 2005
Ok, because I didn't let the tranny hang down all the way because I was worried something would break off. The Chilton's manual says to let it hang and if it's gonna be like that for more than a day, it says to put a jackstand under the engine.
95opal
5 Year Member
Nov 16, 2004
449
20
39
Apr 1, 2005
  • Apr 1, 2005
jump under and visually inspect ur motor mounts for any cracks or tears.if ya have any doubt just replace them.energy suspension has the motor and tranny mount kit.major improvement over the stock mounts.
FastFord
380
Washington
Apr 1, 2005
  • Apr 1, 2005
I agree.. in fact, I would replace them regardless!!
KingDiamond
637
Chicago, IL
Apr 1, 2005
  • Apr 1, 2005
I read people have vibration issues with those polyurethane mounts.
95opal
5 Year Member
Nov 16, 2004
449
20
39
Apr 1, 2005
  • Apr 1, 2005
ive run them on 3 of my last 5 stangs including my current one and i love them the entire drivetrain is tighter.no more vibe than before esspecially if ur stock mounts are worn.
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Apr 1, 2005
  • Apr 1, 2005
I have the prothane polyurethane motor/tranny on my car for over a year. No major vibrations over the stock ones.
J
Bad Vibration
  • jefffletch47
  • Feb 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 2, 2026
dgrinnan
D
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
T
Fox *Solved* Motor mount bolt question
  • TDM389
  • Mar 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 22, 2026
TDM389
T
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
Can makes noises when driving poping
  • Creomod
  • Oct 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2025
Creomod
