  • SN95 4.6L Mustang Tech
Question about pilot bearing
  • Thread starter Thread starter Dope 97GT
  • Start date Start date Aug 31, 2006
Dope 97GT
439
Rochester, NY (SUNY Brockport)
Aug 31, 2006
  • Aug 31, 2006
I am installing my flywheel and clutch and I need to know if there is a O-ring seal that you use to install the pilot bearing. Because the guys at ford say they cannot find that and I have no idea how it goes in otherwise. In my haynes manual it says there is a o ring seal and you press it on but my pilot bearing didnt come with that seal and i cant remember when i took mine out if there was one or how its held on there.
Any help would be appreciated.
RandyStinchcomb
1,159
Randallstown, Md
Aug 31, 2006
  • Aug 31, 2006
there is NO seal on a pilot bearing
CanadaStang
2,093
Mb
Aug 31, 2006
  • Aug 31, 2006
Also before you go to install the pilot bearing, put it in your freezer for a few hours. It helps.
Dope 97GT
439
Aug 31, 2006
  • Aug 31, 2006
then why does my haynes manual talk about a o ring seal what is that?
and if not how do you put it in just press it in with a hammer and socket?
RandyStinchcomb
1,159
Randallstown, Md
Aug 31, 2006
  • Aug 31, 2006
because someone ****ed-up when writting it, I guess
stangGT97
1,299
Boston area, MA
Aug 31, 2006
  • Aug 31, 2006
Always cross check the Haynes manual w/ another source, it isn't right all the time. Do what canadastang said and put the pb in the freezer for a few hours to contract the metal.. that will make getting it on an easier job. When I had my clutch done, the pilot bearing came out in pieces because whoever did the previous install smashed it on with a hammer.
CanadaStang
2,093
Mb
Aug 31, 2006
  • Aug 31, 2006
As I said earlier, pop it in the freezer for a few hours, grease it up good as well as the opening you are sliding it into. You may have to use a block of wood and a hammer [put the wood against the bearing, and tap the wood with the hammer, don't hit the bearing with the hammer directly] to tap it in but if it's good and cold it should just slide in without having to tap it.
Dope 97GT
439
Aug 31, 2006
  • Aug 31, 2006
so it is metal on metal then to hold it in?
RandyStinchcomb
1,159
Randallstown, Md
Aug 31, 2006
  • Aug 31, 2006
that is correct the steel pilot just presses into the back of the crank
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Aug 31, 2006
#10
  • Aug 31, 2006
  • #10
The Haynes manual covers a wide span of model years so sometimes the info is not applicable to your model. Other times it is just not accurate. But it is a great source of general information.
Dope 97GT
439
Aug 31, 2006
#11
  • Aug 31, 2006
  • #11
thanks guys i appreciate all the input.
yet again this site rocks:SNSign:
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
P
2002 T5 transmission vibration issue
  • puffoo
  • Feb 22, 2026
SN95 V6 Mustang Tech Feb 22, 2026
puffoo
P
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
