  • SN95 4.6L Mustang Tech
question about possible head/cam swap
  • Thread starter Thread starter Texstang9682
  • Start date Start date Feb 21, 2008
Texstang9682
115
Austin, Texas
Feb 21, 2008
  • Feb 21, 2008
Ok so the heads on my mustang (non PI) are worthless they have old springs and leak oil like there is no tommorow.
I'm not wanting to spend any money for PI stuff budget is a huge issue. I do have the PI intake if that matters.
Anyway I have sitting in my garage a very low milage pair of f-150 heads for either a 99 or 00 truck.
Any Pros or Cons either way?
I hear the the truck cams can give some good low end torque. And Its not like it a high revver anyways, cause my max HP on the dyno came at 4650 and Peak Torque came at 2900.
Low end torque is what my car needs desperately.
would I lose too much on the top end to warrent the swap.
Also The heads are low mileage and fee and I would do the work myself. So the only money output would be for new gaskets.
Opinions are apreciated. If you need to know what else is on the car just let me know.
Thanks
BTW the dyno numbers in the sig are way old and I have a lot of problems with the care now the corect peaks are listed above.
Mustang92
SN's #1 1%er
Jun 6, 2001
6,467
South Florida
Feb 21, 2008
  • Feb 21, 2008
Just my opinion but I would see how much you could get from your stock heads from the junkyard. Even if they are useless you may get $30-40 for the value in scrap aluminum, then try and sell the cams from the heads on ebay. If you can get $30 or so out of both pairs you would have enough for a pair or used PI cams to drop in those F150 heads. You can find PI cams for $75 or so used.
My car had a pair of 5.4L 2v heads on it for a few months after my valve seals in my stock 111k mile 2v heads started leaking. I swapped cams and valve springs (because of the aftermarket cams) and the car made the same power as before.
Bill
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Feb 22, 2008
  • Feb 22, 2008
If you need any future reference for the PI Headswap procedure or part numbers, check the link in my signature.
Texstang9682
115
Austin, Texas
Feb 23, 2008
  • Feb 23, 2008
Bill
thanks for the link. lotsa good info
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
Timing chain, guides and tensioner installation (Possible orientation in Intake Stroke)
  • StallionMax
  • Sep 21, 2025
SN95 4.6L Mustang Tech Sep 24, 2025
StallionMax
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
9
Milton Questions, 351 swap newedge
  • 996stang
  • Jul 20, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 25, 2026
Killer351w
K
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
