Question about pressure plate installation
5.0 Nostalgia
904
CT
I am finally putting my car back together after being down all summer for mods. I just installed a new clutch but didn't care for the way bolts were torqued down. I used the correct path, but a few tightened faster than others due to tight dowel pins. Can I unbolt the pressure plate and retorque it without having to buy new bolts or are they stretched out? They were torqued to 18 ft/lbs. I know the pressure plate bolts are soft and should not be reused.
Thanks for the help.
You should be safe. The torque spec for the pressure plate is 12-24 lb ft, so your bolts have some more give to them. I've reused the pressure plate bolts in the past with no ill effects, since the dowel pins are what take the force of the rotational mass from the engine, not the bolts.
