  • SN95 4.6L Mustang Tech
Question about reverse...
  • Thread starter Thread starter SilverBullet00
  • Start date Start date Sep 13, 2004
First Prev 2 of 2
twogts4us
4,188
12
79
Dunedin, FL
Sep 14, 2004
#21
  • Sep 14, 2004
  • #21
NDBullitt said:
There is no syncro for Reverse. There are 3 different things I do that don't make it grind:
1. Put the clutch in and leave it in for a few seconds then put it into reverse.
2. Put it into a different gear then put it into reverse.
3. Put the clutch in and start putting pressure to put it in reverse, then let the clutch out just a little bit as you continue putting pressure and it should slide right in.
Best, most accurate answer/solution.
Venom_Nitrous
416
Spearfish, SD
Sep 14, 2004
#22
  • Sep 14, 2004
  • #22
If it doesn'r pop right into gear and seems to be stuck, that is because the teeth on the gears are hitting together and not meshing like they should. It is NOT a problem. There, as stated above, is just no syncro for reverse. Because of this, you need to
1) put in the clutch in for a couple seconds before shifting into reverse to allow the gear to stop spinning.
2) shift to reverse
3) if it doesn't work or seems locked out ( gears aren't meshing), let out on the clutch and try again to allow the gear to obtain a new position.
4) try reverse again
It may take 1 or 2 times to get it in, it all depends on where that gears stops spinning and if the teeth will mesh right. There is again nothing wrong.
NDBullitt
31
Westerville, OH
Sep 15, 2004
#23
  • Sep 15, 2004
  • #23
Thanks.
First Prev 2 of 2
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
2007 Mustang V6 Auto OD light on and wont go into reverse
  • BlakeusMaximus
  • May 13, 2026
  • 2005 - 2014 Specific V6 Tech
2005 - 2014 Specific V6 Tech May 21, 2026
Clicking sound from driveshaft/rear differential
  • matthewt
  • Aug 27, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Aug 28, 2026
matthewt
C
C4 trans help needed
  • CPH89LX
  • Apr 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 28, 2026
CPH89LX
C
idles perfect then jolts and cuts out when put into Reverse or Drive.
  • shanesstangs
  • Mar 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2026
General karthief
