question about rocker arms
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
I was just reading my muscle mustangs and fast fords and noticed one engine they were working on , it says the engine had 1.7 stock stamped steel rocker arms from a 460 engine and they are on a 5.0, so I check and local parts store has a set of these for 72 bucks for the set .....sounds like a cheap upgrade to me compared to paying 200 for roller 1.7s ......I know rollers will have less friction , but bottom line is a 1.7 is going to open the valve up more , I have a friend with a set of GT40 cast iron heads and he is running a E303 cam but was thinking about paying 200 for the roller 1.7s ......what do you guys think for 72 dollars would it be worth it to try and save some money ......?
well i doubt the extra 130 bucks would buy you all that much hp. seems like a good idea to be. don't forget to check the valve to piston clearence. its not the overall lift that is the problem it has to do with duration.
took a look at these last night , looks like they will bolt up with no issues what so ever , they are about 3/8s of an inch longer from from to back than the stockers ...and the valve tip on a stock one was actually riding out next do the edge and these it looks like the valve tip will be slightly to the inside of the flatest part of the area the valve tip contacts but overall I dont think it would ever cause any issues ........looks like a cheap upgrade especially for any speed density guys that can find a set of cast iron GT40s for cheap ....
