I just purchased a 1996 Ford Mustang Cobra last night, and today the check engine light came on. The car has 96434 miles on it. I checked it with a OBD II Scan tool and this is what I got
PO171 System Too Lean -Bank No. 1
PO184 System Too Lean-Bank No. 2
I cleared the code with my scanner and went to take the SMOG test. The car passed the SMOG fine, but failed the engine computer check. After driving another 30 miles the Check Engine Light Came Back On.
Does anyone know what could be the cause of the car running too lean. I know this is not a good thing as it can blow the motor. This is my first American Car, so I have no clue about what could be causing this. Any help or insight as the what would cause those error codes would be Great. TIA
Also what is the general cost on rebuilding this engine. I want to supercharger the car, but I want to make sure the motor can handle it first.
Problem #2
When I shift from 1st to 2nd or 2nd to 3rd sometimes the tranny grinds even with my foot fully depressing the clutch. Does this sound like the syncros are bad, or is this common with the Cobras?
Problem #2
