Edit: Never mind I just think I mis understood your post
High-6's, huh. You do realize you're looking at about a $40,000-$50,000 investment bare bones minimum, right? And that's without the cost of the car!
No way that's way too much
My setup is 600 hp and not even half your lowest estimate. and I even included every support mod.
3200 MMR MOD 900 short block and oil pump
1300 Patriot stage 2 heads
650 Houston S292 performance cams
2500 Vortech V1 S-trim tuner kit
225 Anderson power pipe
490 8 rib set up
395 Innovators west 18% overdrive crank dampner
205 Proffesional products 75mm TB/Plenum
75 used Mac LT's Cut at flange to make it 3"
80 3" dynamax bullets dumped before the rear
125 custom X
275 Miezere electric water pump/with relay (discontinue model got deal from summit)
220 mondo bypass
400 DIY ebay intercooler set up
300 60lb injectors
225 sct 2400 MAf
225 40amp BAP
750 03 cobra tank and pumps
15 Fpdm wire upgrade
165 Diablo mafia
139 Proffessional products fuel rails ( total crap )
225 SCT Chip one of the old single program chips
100 used modified stage FPDM
11994 so far for 600 rwhp
I want these mods next
60 For 2 Used Aviator fuels used just got them yesterday ( hell of a deal)
1000 I'll get the s-trim converted to a T
900 Nitrous kit with the extras might by this used plan on a 75 shot equals more on a FI car
350 convert the fuel lines and modify the fuel hat.
$14244.00 and It should be close to 700 hp
