jivepepper
600 RWHP!! Nice.
What do you think this setup will make (what I have currently):
Forged shortblock with 17cc dish pistons
stage 3 patriot heads
comp 270's (NA cams, hope it doesn't affect boost)
75mm TB and c&l plenum
bbk longtubes
s-trim with a 3.18 pulley - 6 rib
huge paxton 3 core intercooler
anderson power pipe
lightning MAF
vortech race BOV
ford gt pump with boost a pump
boost a spark
42# injectors
tuned
low 500's? But I don't think lightning MAF can support it. Plus you be maxing out the 42's. Stage 3 heads? Is the shortblock bored?
And in the future I would be upgrading to:
convert s trim to t trim
60# injectors
reichard racing manifold (oval setup)
twin 62mm throttle body
110mm MAF
03 cobra tank with dual ford gt pumps
smaller pulley with 8 rib? crank pulley maybe? 8 inch?
What do you think jivepepper?
Around 650-700 depending on the psi and what type of fuel you run. You might also want to upgrade the fuel lines etc. If I had to do it again, I would have probably have went return style setup
I also see that you modded your BAP and FPDM. Are those mods necessary do you think?
I didn't mod the BAP. But I did a wiring upgrade going to it. The FPDM is modified zone 5/mjchip.
The modified FPDM is good idea once you starting using anything bigger than 2 stock cobra pumps, and it frees up some duty cycle. So does the wire upgrade.
I think I have one of my cobra pumps failing and was trying to get all they fuel I could. I hope once I install the aviator fuel pumps I'll have more than enough.
