question about timing
  • Thread starter Thread starter SliverStang
  • Start date Start date Oct 6, 2006
SliverStang
270
Pineville, LA
Oct 6, 2006
  • Oct 6, 2006
My cars timing is retarded for my nitrous. I want to know what deg do i need to set it to for running all motor. I didn't change it my mech did so i really don't know what to put it back to. THanks
1Bad88notch
62
Leesburg,FL
Oct 6, 2006
  • Oct 6, 2006
I would set it to 12-14 degrees
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Oct 6, 2006
  • Oct 6, 2006
remember you need to remove spout connector to set timing back.
SliverStang
270
Pineville, LA
Oct 7, 2006
  • Oct 7, 2006
my car is carburated and has a msd distriber on it.. do i still have to disconnect anything?
SliverStang
270
Pineville, LA
Oct 7, 2006
  • Oct 7, 2006
well i checked the timing to see what it was. It was at 18 deg. I bumped it up to 32 deg. my car is a 86 mustang with a carburated 331 stroker in it with a 58o lift. Is that were it should be at? Also someone said somthing about takin somting out, do i have to do that on my old car?
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Oct 7, 2006
  • Oct 7, 2006
wow 32 degrees initial timing is set at 32 degree's? If so that is way 2 much. 16 degrees intial is probably good with 20 degrees mech advance looking at 36 degrees total. My 351w has 38 degrees total. But every engine is different. maybe 32-36 total is good.
T
tylerrocks
514
Big Spring, TX
Oct 7, 2006
  • Oct 7, 2006
Yeah assuming that your talking total timing. Have vaccume advance? I'm running 22 initial and 36 total with mechanical advance only.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Oct 7, 2006
  • Oct 7, 2006
just a thought but you can have a dizzy worked (different wieghts) so that you have more mechanical advance and less intial. It is harder to start a car with lots of intial and at lower rpm you don't want all that timing. i bet you can pick up torque and hp at the lower rpm's with a good Tune (for lack of a better term) on your dizzy.
Strange timing issue
  • 92 Bimini Blue
  • Sep 26, 2026
Fox 5.0 Mustang Tech Oct 20, 2026
rednotch
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
Question about my weird timing.
  • 2003 mustang gt modded
  • Apr 22, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 26, 2026
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
2K
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
L
5.4 4v base ignition timing table help.
  • leoleo
  • Aug 16, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Aug 17, 2026
MustangBetts
M
