Adam, you are right on. im too lazy to even correct folks.89MustangGX said:Technically, no -- a posi is a GM limited slip, Trac-Lok is a Ford limited slip. Same idea, but you don't have GM parts in your car. To otherwise answer your question -- all cars like yours came from the factory with limited slip rear ends.
Sicarius428 said:Really depends on what type of driving you do. Most people are happy with some 3.55 or some 3.73s.
Kevin
im not real sure what you are talkin about with the trac lock vs 'positive' stuff. if you want to rebuild your existing limited slipper, get a rebuild kit. they are 50 bucks-ish. some like to pack the clutches tighter - personal preference on that.shorty1993 said:final drive i have already decided on 3:73 all the way. what i am refering to is the actual switch from limited slip to positive. what all parts are needed. just a new differential or what. not real sharp on rear ends.
HISSIN50 said:Chris, i thought you were going for a locker, but was not sure. yep, that be it. remember the car will be useless except at the track. inside wheel in a turn turns slower - unless it cant.
point taken. i am willing to make some compromises, but that is one i would not do. so you're right - my opinion took over in that statement. my bad.89MustangGX said:Useless is an awfully strong word -- there are alot of people who run lockers and spools on the street -- although it's not very easy in "non-dry" weather.![]()
as i recall, some folks use pumpkin fluid for open diffs to stiffen up the trac lok. it is at a cost of clutches needing more frequent replacement, but it works well (reportedly, mostly in auto X stuff i have read).
