Question about wiring
From the wiring diagram, the Light Green/White wire controls the turn lamp (and signal in instrument cluster). The brown wire controls the license plate lamps and front/rear side markers. I can send you a diagram if you need it.
yeah man check this......i tapped into the brown wire with a power line into a sleeve along with a wire that crosses over on the same side....on the other side of the sleeve 4 white wires going into the headlight for the halos and leds....and still nothing working cep the ember
