  • 1994 - 1995 Specific Tech
Question - dropping the oil pan
  • Thread starter Thread starter GRGT1994
  • Start date Start date Sep 11, 2005
GRGT1994
1,034
  • Sep 11, 2005
I think I need to put a new gasket in for the oil pan. I am dripping a good amount of oil.
The leak started after I installed a new balancer (OEM one separated). When the stock balancer gave way, the outer ring road down onto the front of the motor (timing cover and oil pan I think).
So when I first saw the leak, I thought it was because I forgot to silicone the bolt and washer. I pulled the bolt back out, and sealed that up. Still leaks.
I'm guessing its from the oil pan to block seal.
So with that story, I am wondering how big a job it is to drop the oil pan and put a fresh seal on there. Any thoughts or suggestions?
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Sep 11, 2005
  • Sep 11, 2005
You can "snake" the old gasket out (oil pick ups in the way) and snake the new one in. Houst the engine up a bit to give you more room to play with.
Question did you RTV the Key on the crank and on the balaner key way or just the washer and bolt??
GRGT1994
1,034
  • Sep 11, 2005
Actually, I had the shop do it while they were looking for my electrical short. So I guess I should start there.
I checked the Haynes manual and see that pulling the pan completely is a major job. So I'll be taking a closer look to try to find the source of the issue before going down that road.
stangbanger94
203
Bergen County, NJ
Sep 11, 2005
  • Sep 11, 2005
did you check the seal on the front of the timing chain cover? sounds like that could be whats leaking
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Sep 11, 2005
  • Sep 11, 2005
yeah, it could be the front main seal leaking, and you will just have to yank the water pump/timing cover and replace it. No biggie.
Scott
GRGT1994
1,034
  • Sep 11, 2005
It's not dumping that much oil, just making a mess. I'll pull it apart next weekend.
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
Who the hell puts the wrong spark plugs in a 3.8L?
  • snowstang
  • Mar 25, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 3, 2026
LILCBRA
2001 v6 New compressor issue
  • badmech
  • Apr 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Apr 30, 2026
badmech
Engine Cheapy Fox body 7qt oil pans?
  • rednotch
  • Mar 25, 2025
Fox 5.0 Mustang Tech Apr 15, 2025
08GT500
N
Edelbrock 1405 Setup
  • nathantaylor200
  • Nov 4, 2025
Classic Mustang Specific Tech Nov 5, 2025
nathantaylor200
N
