Question for just us 2.3 guys/gals
cheapstang
48
Omaha, Nebraska
Alright so i just met a guy that autocrosses his gt and is getting rid of the old shocks, struts and springs. If i were to take the 5.0 springs and cut a coil on the heavier front springs...Would the cut coils make it stiffer but kind of cancel out the fact that they are supposed to be for a heavier front end? Im just going to take the front 5.0 coils and cut a single coil. i want a good 1.5"-2" drop. I hope you guys all understand my question...are the rear coils different? or could i just leave my 2.3 springs on the back?
Thanks a bunch!
-Kyle-
I would do the cut and try technique, no more than 1/3 to 1/2 coil at at time. It will be stiffer in any case.
It takes some care to get the right height, and not too low. I did the rear carefully, then cut 3/4 coil off the fronts, and ended up about 1/2 in too low in front. I put 4 cyl springs in front on a 5.0 car.
You can cut the rear springs, only on one end, but I think that is the case with all four.
I cut the rears on my 82. They were orig 255 V8 springs. I ended up with 3/4 coil cut.
I would cut in no more than 1/2 coil increments, so that you don't cut two much.
