  • SN95 4.6L Mustang Tech
Question for SVTtech
  • Thread starter Thread starter damacman
  • Start date Start date Aug 24, 2006
damacman
529
Phoenix, AZ
Aug 24, 2006
  • Aug 24, 2006
How can I tell if the tensioner on my GT needs to be replaced? At WOT, I'm getting a sound from the front of the motor that sounds a little like detonation (obviously, this is a possibility as well), as well as some popping and clunking when driving at slow speeds and in and out of the throttle slightly. I've read the numerous threads about how folks discoverered their tensioner was bad after they pulled it off, but I gots a blower mounted in front of mine . . . that ain't so easy. I don't want to go to all that trouble to find out it was something else.
Recommendations?
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Aug 24, 2006
  • Aug 24, 2006
can you get your hands onto the serpentene belt? if you can pull on the belt and see if you can move the tensioner this way.. If you can not move the belt when you pull on it hard then the tensioner is seized.
timeless2
Vi Veri Veni Versum Vicus Vici
Admin Dude
202
154
the Shadow Gallery
Aug 24, 2006
  • Aug 24, 2006
Centris can sometimes be belt eaters. Are you sure the belt you have just isn't going bad?
damacman
529
Phoenix, AZ
Aug 26, 2006
  • Aug 26, 2006
No, I'm not. But the belt only has about 5,000 miles on it. I'll look into both suggestions in the morning. Thanks!
Fuel Pressure Regulator or something else?
  • SuperStang83
  • Nov 17, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 25, 2024
BrightVa
Wheels-Tires LS mii swap and rear rim size/axle questions....
  • 78mIIman
  • Feb 2, 2025
1974 - 1978 Mustang II Talk & Tech May 6, 2025
78 Mach1
D
Brakes 1966 Mustang convertible 289, Auto - Disc brake conversion issues
  • DRGunn427
  • Feb 26, 2025
Classic Mustang Specific Tech Jul 23, 2026
All Stock93
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
  • D Durden
  • Oct 20, 2025
  • 2 3
4K
