Do any of you have it hooked up on the low speed setting? If so, do you have any cooling issues, or does it work just fine?
I ask because I have a Taurus fan and have it wired through a thermo-switch, on the high speed side. I am going to rewire it to use both speeds via an interrupt relay. I am going to have the low speed run when the thermo-switch turns it on for cooling purposes. I am going to wire the high speed side through my AC cycling switch, so it is on when my AC is on.
Basically I am going to wire it how a normal two speed fan would run in stock form, low speed for engine cooling, high speed for AC. I just don't know what to expect when it comes to the low speed and engine cooling.
