88GTMustang New Member Oct 31, 2003 247 0 0 LA california May 30, 2005 #1 May 30, 2005 #1 is the 93 comp the same as the ones from 89-92? would it work fine if i had a complete wire harness from a 89 and used the 93 comp. ?
7 7upstang New Member Sep 20, 2004 75 1 0 Calgary, Alberta May 30, 2005 #2 May 30, 2005 #2 I'm not sure, but I believe the differences in the computers had more to do with the model than the year. There are subtle differences between vert computers and coupes as well as differences between automatic computers and 5 speed computers.
HISSIN50 "How long does it take to get help in here? 15 Year Member Nov 29, 1999 31,179 34 129 May 30, 2005 #3 May 30, 2005 #3 yeah, need more info. there are SD and MAF puters, auto and stick puters, and then some oddballs of those. you should look at a schematic for each puter to be sure the function of each pin matches with the harness and other puter. good luck.
super302 I'd do anything for free Bapples May 29, 2004 2,878 1 0 Davenport, IA May 30, 2005 #4 May 30, 2005 #4
88GTMustang New Member Oct 31, 2003 247 0 0 LA california May 31, 2005 #5 May 31, 2005 #5 yup both are for a manual trans and both are mass air comps... can i get some more input?
jrichker StangNet's favorite TOOL In Remembrance. Thank you for your contributions Mar 10, 2000 27,512 2,813 234 Dublin GA Jun 1, 2005 #6 Jun 1, 2005 #6 88GTMustang said: is the 93 comp the same as the ones from 89-92? would it work fine if i had a complete wire harness from a 89 and used the 93 comp. ? Click to expand... Should work OK, all the pins are the same. See http://fordfuelinjection.com/?p=6 for more info
