I'm very much a novice when it comes to diagnosing and fixing transmissions. If possible, I'd like to get some input from you guys about my symptoms.
I have a 90 Gt with a 347 and Tremec 3550 trans. I bought the car with this set up and it runs fine in other gears...it seems to be just an issue with reverse.
My clutch pedal is very heavy (not sure if it's just a racing clutch or if something needs to be adjusted)
And my trans doesn't like to go into reverse....many times as I try to shift into reverse I can feel the vibration of the gears spinning and am almost trying to force the lever into reverse.
I'm not sure if my clutch is overly worn....clutch needs adjusting...shifter needs adjusting...is there something wrong with the trans?
Anyone have links to articles here or how-tos, that would be great too. Please don't flood this with "you should just get a new trans because that one sucks" kind of comments. I'm looking for input on how to tackle my drivetrain.
Thanks in advance.
Thanks in advance.
