question on clutch cable
  • Thread starter Thread starter superspec
  • Start date Start date Sep 1, 2009
superspec
78
  • Sep 1, 2009
2 days ago my shifts got pretty hard, then i realised ththat the clutch pedal had to be pushed all the way down with a good bit of force into the floor to smooth the gear changes. i havent driven the car since then and finally got out today to do some clutch adjustment. when i rolled under i saw where the cable goes into the cover on the bellhousing. right where the cable goes in, the insulation is torn away and the cable wrap is kind of unwound a little bit. instead of adjusting the cable i got another one on the way and should have it in about an hour.
how long should it take to change the cable out? any pointers on things to do or not to do to speed up the process?
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
2003 gt, clutch pedal stiffness.
  • 2003 mustang gt modded
  • Feb 15, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 17, 2026
Removing speedo cable from the VSS
  • 91AOD5.0LX
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
91AOD5.0LX
Drivetrain Time to pull and lube the clutch cable
  • LX Dave
  • Dec 21, 2024
2K
Fox 5.0 Mustang Tech Jan 7, 2025
limp
Drivetrain Clutch cable?
  • flashback87
  • Jul 14, 2024
  • 2 3
4K
Fox 5.0 Mustang Tech Sep 29, 2024
