Question on vibrating motor/trans again?
  • Thread starter Thread starter Numbles
  • Start date Start date May 11, 2005
Numbles
998
Chicago, IL
May 11, 2005
  • May 11, 2005
Well I talked to my local machine shop about balancing my flywheel to my pressure plate. Its the last thing left to find where my vibration is coming from. I bought the car with a 306 and h/c/i on it already. And it had horrible vibration through the shifter. So I put in a romac balancer, flywheel from my 95gt, new clutch, new tob, new pilot bearing and rms. And indexed the bellhousing. The car doesn't vibrate as bad under wot anymore. Vibration starts around 4500 rpm and up in gear. And 3500 and up in neutral. But it is worse in neutral. Its rpm related not mph related either.
When I looked at the old balancer and flywheel I found some interesting stuff. It looks like the motor was balanced via drilling material out of the flywheel. Does anyone else have 1/4 inch diameter holes drilled into the flywheel. They dont go through but I imagine they are for balancing. There is one drilled into the balancer about 3mm deep and 4 seperate ones in the flywheel drilled almost all the way through. Im trying to sort out the imbalance somewhere. Anyone have any ideas.
FWIW. The bellhousing was .033 off and there were only 2 dowels holding the clutch in before swapping my tko in. Ive done everything I can so far to try and get rid of the vibration. Any ideas would be great.
Mike86Stang
Advanced Member
Apr 11, 2000
10,296
Red Lion, PA
May 11, 2005
  • May 11, 2005
Well if it helps I had a similar problem & this was the cause.
silverstripes
81
monroe, LA
May 12, 2005
  • May 12, 2005
They made two different weight flywheel and balancers. A 50oz. and like a 28oz. i think. You need to know which weight goes on your motor and match.
Numbles
998
Chicago, IL
May 12, 2005
  • May 12, 2005
That is something I have thought about. But the vibration would be like having a balancer go out if you put a 50oz setup on a motor balanced for 28. The vibration smooths out on the top end but is kinda bad around 3500 to 5000.
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
Drivetrain Vibration after changing clutch
  • keel
  • Oct 18, 2024
Fox 5.0 Mustang Tech Nov 8, 2024
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
