I've noticed a squeeking noise comming from the passenger door when the radio is on. Basically it sounds like a cricket , any ideas how to solve this problem???
Same here, I figured it was something loose in the door panel as I usually hear it when I have the Mach kickin out some Chevelle or Breakin Benjamins loudly.
mine does that noise you speak of over bumps, and i just reach over and punch the passenger door plastic as hard as possible, and then it will be fine for a month. when it comes back, repeat.
Its the rubber window seal that seal between the passenger window and the small back window and how the wind hits the back window pillar that has to big of a gap.
