Questionable Part
1991RWHP
59
Illinois
Was surfing around when i found a picture that confused me. Was just wondering what the part is called that is "circled" in red. Also what does it do(Kill 2 birds with 1 stone!)
Thanks for your help!
It's more commonly known as a 'Quad Shock' or the 'Quadra-shock rear suspension' as Ford calls it, it does keep the wheel hop down. A lot of people say that you can remove them with aftermarket control arms and be fine; others still experience wheel hop even with good control arms; its a crap shoot. Personally I think its best to try to keep them on either way if possible.
You can get them from Autozone for 25 bucks each, but you have to ask for them under 'steering damper' though. :scratch:
I took them off of my car, more for tire clearance issues than anything else and saw no ill effects, but then again the suspension is hardly "stock" on my car. Plus you can drop a few pounds off of the car by removing them, if that matters to you.
Yea my car doesn't have them on there anymore, i saw a picture and was totally unaware of what they were or what they did. I don't really notice much wheel hop, but i guess there has been mixed feelings about them. Anyone elses input, please let me know!
I imagine that a good set of shocks along with the LCAs will also help avoid wheel hop if you remove the quads. My car still has all the original suspension and I get some wheel hop when I try to "power brake" a burnout.
But soon my car will NOT have stock suspension muoahahaha. :rock:
When will this myth die?
There have been plenty of posts made by people with high dollar suspensions asking why they still have wheel hop. They toss the "useless" quads back on and suddenly it's all gone.
You can't issue a blanket statement saying quads aren't needed with aftermarket suspension components because there have been plenty of posts made by guys with aftermarker lca's and uca's who ditch the quads and still have it. Its a 2lb part and it works.
I still have quads on my car with MM lowers and Ford HD uppers.
they are usefull for a stock or lightly modded car, once you start really modding the car they are useless junk and dont prevent wheel hop as your hp and tq goes up, many ditch them for like said above wider tires,rims and after market control arms.
U no longer need them if u have Aftermarket lca's.
You read absolutely none of the responses above before posting this, did you? ;)
Quad shocks are a good idea and do what they were intended for. If you've got aftermarket lowers, then try it without and see how it works. If it hops, put them back on. Simple as that.
....or, throw them away, then buy a new set when you realize the mistake you've made. :shrug:
I read them all Gearbanger, not sure what ur getting at here. I was just posting my opinon on them and trying to support what has worked for me. Was I wrong in something. I went back and re read it all and don't see where I'm out of line. If I'm looking at somethign wrong, please let me know. I don't want to be giving somone false info by accident.
I have done it both ways. Had a 5 speed car with Hpm mega jrs and rear quads. No wheel hop.
92 aod with a 3500 stall and 351, lakewood traction action lca and bfg d/rs. No quads b/c of clearance issue and no wheel hop and great traction.
Can't you simply install a set of mac's adjustable snubers and use adjustable upper control arms to change the pinion and add a little pre load to eliminate any left over hop from deleting the quad shocks?
I'm not saying you were wrong....if it worked for you, then that's great. Your statement just sounded so "matter of factly" and dismissive to alternate opinions to aftermarket lower control arms that I thought I should address it. Not everyone has been as lucky as yourself. Lower control arms that experience less flex and that have harder durometer bushing will certainly help the situation and like I said it a good portion of the cases will cure the issue, but the only thing that really seems to eliminate the wheel hop altogether is the factory quad shocks. :shrug:
Either way, my comment was meant to be a little more light hearted....hence the " ;) "
Thats cool Gearbanger. I was just throwing my .02s. I been through a few diff rear set ups between my own cars and wrenching on close friends. I guess we have all been fairly lucky as u say. Could just be our local track, none of us really exp any wheel hop and all the said cars were 12-11 sec ones. So yea. For the op, there are many ways to do it, Quads work best when on a budget but u can get into fully adjustable susp pieces for quite a bit of cash and make it work brillantly for u.
