Hi all,
I am about to purchase an '03 Sonic Blue Cobra coupe private party. It is mostly stock. The owner has some uninstalled items he will throw in with the deal (benefits of a Military to Military handshake and smile deal). The car is very clean and very well maintained and I will run a carfax on it when I get the VIN. I have searched the forums and have not found out some basic info on the '03 Cobra.
What are the stock injector sizes?
What is the stock gear ratio?3.55?
What is the stock upper pulley size?
Will any mustang 8.8 ring and pinion fit in a Cobra IRS diff?
What can the stock fuel pump handle/what is its rating/are there one or two?
What size is the stock MAF and does it need to be larger for upped boost/injectors?(personal experiences on this one)
Will the stock computer safely let the car run more boost with an aftermarket exhaust or will it go lean?
Is the Kenne Bell Boost a Pump a solid add on or a waste of time?
Sorry for all the questions, thanks for any answers you all might be able to lend me.
Thanks,
Mac
Thanks,
Mac
on my ZX10R and have always dreamt of a car that could handle those roads. So, handling will be modestly addressed. The owner also installed a Steeda CAI, Billetflo(sp?) IRS brace, spec III clutch, and a few other small things. A stock sized quick change upper is already installed with a 2.93 sitting in the trunk along with a 4# quick change lower. I am not going to install either until I know for sure I can without damaging the engine. He also had the stock Eaton ported. Also in the trunk just waiting is the Kenne Bell Boost-A-Pump, so thank you for the info on that.
"If you ain't ammo, you ain't *****"
