The other day I pulled my MAF sensor and cleaned it with some alcohol and Q-tip. Let it dry and put it back together. So today I go for a drive and notice some pinging under light load.(I run only 93-94 Octane).I have fought this before,but seemed to get better with my new performers.I backed the timing down to 10* BTDC,It was only at 13* and i still am getting pinging.I have replaced the IAC,TPS is set right.I am guessing it is related to my MAF. Can I disconnect it and run the car to see if that is causing my pinging? Or is there a way to test it to see if it is working correctly. It is a Pro flow meter.
Thanks, Phil.
Thanks, Phil.
Here is a pic it is not very clear though. How can I tell what MAF I even have? The tube the meter sets in says PRO-M on it and that is all. On the bottom of the meter there are some numbers and one of them says 70. I wonder if this is only a 70mm meter? which I would say is too small. I would think I would need a 80mm for sure.
