questions on new cobra
92superstang
33
Mesa, AZ
I recently got a 96 cobra and I has a few questions I hope you guys can help me with. The temp gauge never really stays in one spot. It's not that bad when the air is off, but when it's on it runs in the AL of the temp gauge. I would think this is bad since the car has an aluminum block and heads. Do all cobra's do this? Can a coolant flush and new thermosat fix this, or is there more to it? I was also considering a O/R h-pipe. I'm pretty sure it will set off the check engine light. Do you have to use mil eliminators or will it cause problems. Any info would be helpfull. Thanks.
Do you know if your '96 had the "cooling" TSB performed on it? Call up SVT @ 1-800-ford-svt to find out. Also might want to invest in an aftermarket water temp gauge, as the factory ones are not all they're cracked up to be...
Yes, MIL Elims will prevent the check engine light from appearing on your dash once you swap to an aftermarket midpipe - there are the plug-in variety as well as splice in type; I purchased mine from www.ponyexpressperformance.com :cheers:
In regard to your temperature question---since you don't know what the service history on your car is (at least you didn't say), I'd for sure change out the thermostat and coolant. Also, unless you know they've been done, I'd do the hoses at the same time. Its a fairly easy and inexpensive job that you can do at home and its worth the piece of mind. Believe me, you DO NOT want your thermostat sticking shut and overheating your motor! (ask how I know). In fact, for more piece of mind, I'd probably start a hit list of things to check/replace---hoses, belts, filters, etc. My 3 cents worth :nice:
