Quick Clutch Cable Question
  • Thread starter Thread starter riccorizzo
  • Start date Start date Apr 4, 2004
riccorizzo
165
Binghamton, Brooklyn, Boston
Apr 4, 2004
  • Apr 4, 2004
Every six months I have to back off the nut at the clutch fork to get the clutch to grab tight enough. Now theres slack in the cable and not much room left for me to back off the the threaded rod.
After the adjustment the pedal grabs at the floor, now six months later it grabs very high again and will slip if I lug the motor. Any ideas?
MUSTANGJOE
Silver Stanger
1,644
17
59
Apr 4, 2004
  • Apr 4, 2004
Do you have an aftermarket adjustable quadrant and firewall? If you do get an original clutch cable from ford (dealer) and put that in. These adjustable cables are full of $hit. They stretch and snapp...!
riccorizzo
165
Apr 4, 2004
  • Apr 4, 2004
Aftermarket quadrant with 3 spots on it, no adjustment at the firewall. I dont mind the setup. I just want to know if these issues point to problems with the cable or the clutch itself...
5.0 HOtrain
2,247
New Hampshire
Apr 4, 2004
  • Apr 4, 2004
What about the cable, is it stock or an aftermarket adjustable one?? If it's aftermarket, loose it and go back to the stock ford one.
riccorizzo
165
Apr 4, 2004
  • Apr 4, 2004
aftermarket adjustable.. how can u use a factory one with an aftermarket quandrant? theyll be no adjustment.. simply the three spots on the quadrant? thats enough.. by the way.. this is on a lincoln mark vii
J
jerry beach
2,671
Ocala,FL
Apr 4, 2004
  • Apr 4, 2004
Loose cable+slipping clutch= worn out clutch or pressure plate. As long as there is no tension on that cable with the pedal up, the cable is not at fault.
5.0 HOtrain
2,247
New Hampshire
Apr 4, 2004
  • Apr 4, 2004
Did you read the instructions with you're quadrant? One hook for stock cable, one hook for adjustable cable, and the other if I remember correctly is for either cable with a firewall adjuster. It's been two years since i've done mine, might be wrong
mike.
riccorizzo
165
Apr 4, 2004
  • Apr 4, 2004
the car was converted when i bought it.. im pretty sure its hooked to the middle notch on the quadrant..
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
Drivetrain Clutch cable?
  • flashback87
  • Jul 14, 2024
  • 2 3
4K
Fox 5.0 Mustang Tech Sep 29, 2024
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
M
2001 v6 heater hose quick connect question
  • mnky99
  • Sep 24, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 26, 2025
mnky99
M
