quick coil help please
  • Thread starter Thread starter 1bad67sbf
  • Start date Start date May 23, 2011
1bad67sbf
674
N. VA
May 23, 2011
  • May 23, 2011
i am putting a 92 "roller" back together and need to know if the coil needs what i want to call a Condenser but it may have another "correct" name. it is the round cylinder that mounts with the coil. i see the 94-95 uses one and the van i got my motor from (88) uses one but does a 88-93 fox need one? i tried to look one up on autozones web site but had no luck. thanks
Mustang5L5
Mod Dude
Feb 18, 2001
43,366
18,112
224
Massachusetts
May 23, 2011
  • May 23, 2011
I honestly have no clue what you are talking about.
Can you explain differently?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
May 23, 2011
  • May 23, 2011
No condenser in the EFI 5.0's ignition system...
Some audio fanatics might add a condenser on the ignition switch side of the ignition coil (red/lt green wire) to filter out some of the electrical interference, but the ignition system itself does not use a separate external condenser
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring Mustang FAQ - Wiring & Engine Info Everyone should bookmark this site.
Ignition switch wiring
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pinout
Fuse box layout
Saleen0679
876
24
49
Yakima, WA
May 23, 2011
  • May 23, 2011
Ignition condensers are used on the older points type ignition systems mostly phased out in the mid 70's. What you are probably seeing in the 94-95 is the RFI filter capacitor.
1bad67sbf
674
N. VA
May 23, 2011
  • May 23, 2011
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
May 23, 2011
  • May 23, 2011
We have the same idea. What you are seeing is used to filter out the electrical noise to prevent Snap, Crackle and Pop from making their musical debut in your car audio system...
Mustang5L5
Mod Dude
Feb 18, 2001
43,366
18,112
224
Massachusetts
May 23, 2011
  • May 23, 2011
Oh.
Nope...my 88 doesn't use one
1bad67sbf
674
N. VA
May 23, 2011
  • May 23, 2011
thanks, one less thing to deal with.lol
  • dan50
  • Jul 18, 2026
dan50
Brakes Need help ID’ing which brake lines and seals I need
  • AnthonyA1234
  • Apr 2, 2025
Fox 5.0 Mustang Tech Apr 14, 2025
limp
Electrical Innovate PSB-1 is DOA? Am I an idiot? All plausable. Please Help
  • Dontknowchit
  • Apr 26, 2025
Fox 5.0 Mustang Tech Apr 26, 2025
Dontknowchit
Brakes ABS in a Fox - Mark Bettin
  • AeroCoupe
  • Mar 28, 2025
2K
Fox 5.0 Mustang Tech May 17, 2025
AeroCoupe
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
