  • 1994 - 1995 Specific Tech
Quick Fox TB question
  • Thread starter Thread starter rio95
  • Start date Start date May 22, 2005
rio95
829
Grand Rapids, MI
May 22, 2005
  • May 22, 2005
If I use a stock TB (60mm right?) then will the 65mm egr spacer that UPR has be alright to use. It is the smallest, so I'm guessing I have no choise.
Also, what is the run down of keeping the cruise. What parts? Procedure?
Stangfreak95
add a 4
3,571
In your sister. If none, your mom
May 22, 2005
  • May 22, 2005
Well I guess you wont have a choice to use the 65mm spacer. Is this the EGR delete spacer ? Your tb is smaller than the spacer but I dont see why it wouldnt work.
About the cruise...the ONLY part you need is a fox 87-93 5.0 cruise cable. Thats it. You'll have to take the driver inner fender (plastic) that holds with a few clips. Then you'll gain accessibility to the cruise unit, which is wrapped in a rubber "shield". Take it off. Take the unit and open it up to release the stock cruise cable. Remove the stock cruise cable from the engine bay. Install the fox cruise cable in the engine bay and same route as the stock cable. It will attaches the same way as the stock cable. Works like a charm.
I have like 4 pics of different parts/views for this cruise conversion. If you want them let me know.
Mario
rio95
829
Grand Rapids, MI
May 22, 2005
  • May 22, 2005
Yeah, I don't think the extra 5mm is going to hurt anything. Those pics would probably help but I not in too big a hurry.
thanks
RIO5.0
6,892
N.H.
May 22, 2005
  • May 22, 2005
You should be all set...although I had to open up my UPR delete to match the intake, it was smaller than the intake opening.....
rio95
829
Grand Rapids, MI
May 23, 2005
  • May 23, 2005
I didn't think about it like that. (I should just get it the same size as the intake opening right). It will be on a street heat intake, so I believe I should get a 70mm. Althought the TB will still be smaller than this.
rio95
829
Grand Rapids, MI
May 23, 2005
  • May 23, 2005
I was wrong, the street heat is 75mm.
Engine Catch Can or not?
  • R82148V
  • Mar 4, 2026
Fox 5.0 Mustang Tech Mar 6, 2026
ctandc
C
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
W
I need a 1997 Mustang PATS A expert!
  • Wolfdogg
  • Oct 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 5, 2026
Gt40 e303 combo questions
  • 99mustanggt2018
  • Mar 30, 2025
1994 - 1995 Specific Tech Mar 30, 2025
KRUISR
Engine Sick of stock TB and EGR spacer...
  • 91GTstroked
  • Dec 15, 2024
Fox 5.0 Mustang Tech Dec 19, 2024
General karthief
