  • SN95 4.6L Mustang Tech
Quick gear and auto question.
  • Thread starter Thread starter paintballpyro1
  • Start date Start date Sep 12, 2008
paintballpyro1
118
Michigan
Sep 12, 2008
  • Sep 12, 2008
I have a 96 gt with the auto trans. Im looking at buying a whole rear-end with 4:10 gears(ford motor sports) w/ rear girdle for $300 hasnt been driven on. 1st does that sound like a good deal? Also i was reading that it will/can cause damage to the trans which i cannot afford to roast another one. Will a speed cal fix that problem(know it fixes speed/odo)
04YELLOWGT
1,135
Indiana
Sep 12, 2008
  • Sep 12, 2008
Are you talking axles and all? If so I would be careful because that is too cheap.
Also it won't hurt your trans it will just throw off your speedo. A speed cal doesn't work for an auto you will need to get an SCT Tuner.
paintballpyro1
118
Michigan
Sep 13, 2008
  • Sep 13, 2008
Yea it is complete minus brakes. He said gear were 200, girdle was 200 and the carrier was close to 400. It looked like it was a project car and just funds ran out and now he is parting out. I asked about it alittle more so we will see what he says.
Anyway yea i was reading by changing the gears it changes the shift points and can damage it. I have been looking at the sniper special force, would that work for the gears and shift points?
Flghtmstr1
572
Springfield, PA
Sep 13, 2008
  • Sep 13, 2008
The shift points don't change; they are RPM-triggered not MPH triggered. I drove my car after getting gears put in without a tune to compensate, and it shifted the same. The only difference was that my speedo read high.
paintballpyro1
118
Michigan
Sep 13, 2008
  • Sep 13, 2008
Well i ended up getting the sniper tuner anyways cause you do a couple other things that i have on my car. Should i raise the rpms that it shifts at with the new gears or just leave it?
04YELLOWGT
1,135
Indiana
Sep 13, 2008
  • Sep 13, 2008
Leave it. Just change the gear ratio to 4.10s to get your speedo correct.
paintballpyro1
118
Michigan
Sep 13, 2008
  • Sep 13, 2008
sounds good then. This is really my first swap and will be first geared car. What weight fluid should i use?(i know i need friction modifier also). I kinda searched and people said 80-90, 75-90 or synthetic 70w-140. What would be best for it sense it has no miles on it. O and i cant find my haynes manual but how much does it take?
SOLD SOLD!!!! 1993 Notchback Roadracer For Sale. She's a beast!
  • Boydster
  • Apr 25, 2025
Fox Body Mustangs For Sale (1979-93) Apr 25, 2025
Boydster
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
Build Thread 1978 Fairmont. I bet somebody back home’s thinkin’…I wonder why he don’t write..?
  • CarMichael Angelo
  • Aug 27, 2020
  • 137 138 139
3K
394K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 7, 2025
Rdub6
