quick GT40P question
  • Thread starter Thread starter 90LX5spd
  • Start date Start date Aug 21, 2005
9
90LX5spd
53
PA
Aug 21, 2005
  • Aug 21, 2005
Will stock tubular exhaust manifolds work with GT40Ps? I've heard yes and no. I don't have the bucks for headers yet and would like to get by with the stockers for now. Thanks.
C
clarkjr
716
NC
Aug 21, 2005
  • Aug 21, 2005
They should but you may have to run a short plug in the rear-most cylinders and be careful with your plug wires. I know that the standard MAC shorts will work this way so I will guess that the stock header will be similar.
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Aug 22, 2005
  • Aug 22, 2005
No. The plugs, reguardless of size are going to hit the primaries. The problem is that the plugs are in a different angle than typical Ford heads, and come almost straight out of the side of the head, and straight into the header pipes. The "P" headers come straighter/further off the heads to clear the plugs. MAC shorties will not clear, but MAC full lengths will because they come out far enough to clear them.
Anyone saying they're using short plugs or certain headers, are either extremely lucky or are running regular GT40s, and not the P's.
9
90LX5spd
53
PA
Aug 22, 2005
  • Aug 22, 2005
Ok, if that's the case, where can I get shorty headers that work with GT40Ps? My usual sources (Jegs, summit, etc.) make no mention of P specific headers.
C
clarkjr
716
NC
Aug 22, 2005
  • Aug 22, 2005
See if MAC will sell you the P specific headers or Central Coast Mustang.
I bought two pallets of GT40P heads and I had some brand new MAC short headers. I bolted the headers to the heads and I did have regular length spark plugs installed. The rear-most plug did make a tad bit of contact with the header, or there was so slight clearance I knew the wire would never go on - don't recall exactly. Either way, I then installed a short plug back there and had room for the plug wire.
If you don't want to take a chance, get the P headers but if you know someone that has some standard MAC shorts lying around, try them and see.
jaymac
995
Northern Mass
Aug 22, 2005
  • Aug 22, 2005
I have BBK shorty headers and and regular plugs for the explorers.
You can search for my thread titled "pics of gt40P shorties and BBK headers" or something like that. To change plugs, I had to remove the drivers side header, (PITA), and a motorcraft plug wire turned backwards (you'll see it in the pics), but they work!
jaymac
995
Northern Mass
Aug 22, 2005
  • Aug 22, 2005
http://forums.stangnet.com/showthread.php?t=567742
there's the link...
darthcual
985
Arlington, TX
Aug 22, 2005
  • Aug 22, 2005
Ford Racing now makes "P" specific headers. Hope that Helps.
9
90LX5spd
53
PA
Aug 22, 2005
  • Aug 22, 2005
Cool! Thanks guys.
Daniel50
716
Discovery Bay, CA
Aug 22, 2005
#10
  • Aug 22, 2005
  • #10
i got the p ford racing headers and they will fit perfect for about 230 shipped to you from summit
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
Engine Keeping O2 sensors lit with long tube headers
  • keel
  • Jul 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
C
Fuse help please. 73 Mach 1
  • Curtis Harper
  • Oct 19, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 28, 2026
Curtis Harper
C
M
Gt40p headers
  • Mike3
  • Oct 14, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Nov 1, 2025
Blackhawkxx
