quick heatercore hose question please!
  • Thread starter Thread starter mob
  • Start date Start date Sep 16, 2006
mob
the guy who hits on his mom
20+ Year Stangneter
Oct 3, 2003
2,566
136
104
Dallas, TX
Sep 16, 2006
  • Sep 16, 2006
Hey guys, I bypassed my heater core not too long ago, just connected the two hoses with a fitting. I saw latley that it was kinda leaking through the fitting so i tightened the clamps. Yesterday i was driving, smelt coolant bad, temp went way up to the red and when i pull in my driveway smoke was coming out of the hood. Definatly the 5/8 hose split in half. I have the hoses off now, I want to just buy a half circle hose and connect them with just one hose so it dosent happen again. But in the bigger hose there is a small metal thing. Im not sure what it is, do i need that? or can i just run a normal hose to connect the two lines, need answer quick please! thanks.
Will it be alright to put the 5/8 size hose on the 3/4 if i make the clamp tight enough? thanks.
8950HO
658
  • Sep 16, 2006
http://forums.stangnet.com/showthread.php?t=659929
mob
20+ Year Stangneter
Oct 3, 2003
2,566
136
104
Dallas, TX
Sep 16, 2006
  • Sep 16, 2006
THANKS! i tried searching must have missed that thread, thats perfect!
TRWXXA
190
RIGHT BEHIND YOU!!!... Made you look.
Sep 16, 2006
  • Sep 16, 2006
The metal thing is the heater core inlet restrictor. It's purpose is to reduce the coolant pressure inside the heater core at high engine rpm, and extend the life of the core. Keep it. New heater core hoses don't come with it, and you'll want to have it if/when you replace your heater core. It's a $16 - $20 part, believe it or not.
8950HO
658
  • Sep 16, 2006
I bought a new inlet hose from Ford when I replaced my heater core about 4 months ago.
It already had the flow restrictor installed in the hose.
TRWXXA
190
Sep 16, 2006
  • Sep 16, 2006
You are correct. The OEM, Ford hoses do have the inlet restrictor.
M
2001 v6 heater hose quick connect question
  • mnky99
  • Sep 24, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 26, 2025
mnky99
M
M
  • mnky99
  • Sep 5, 2025
mnky99
M
M
2001 evap/heater core questions
  • mnky99
  • Sep 3, 2025
SN95 V6 Mustang Tech Sep 3, 2025
mnky99
M
E
Finished my Fox Hydroboost Install - Tips
  • Engineer Duane
  • Apr 9, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2025
Engineer Duane
E
M
2001 v6 heater return pipe leak question
  • mnky99
  • Nov 11, 2025
SN95 V6 Mustang Tech Nov 11, 2025
mnky99
M
