Quick Help With C/C Plate Install!
94GTLaserRC
Squint as you approach, lest you be blinded by my
Well, as it turns out, none of the 4 "possible" helpers was able to make it today, and since my Steeda's are promised out, I need to take a stab by myself :rlaugh: at putting in the MM's
Question: ON the instructions link below, step 4 says to put load on the control arm. Step 15 says to repeat step 4 through 14 for the other side of the car. However, in steps 4-14, it NEVER mentions when to release the load on the first side. I only have one jack, so I dont know If I REALLY have to wait until one side is done to do the other.
Am I missing something? :shrug:
RC
http://www.maximummotorsports.com/instructions/MMCC9994v4r4.pdf
eades5.0 said:
Dude do one side at a time, then take the jack to the other side and start over
That's how "common sense" would dictate, but I was curious as to why the directions said that...Actually, if you read the directions, it NEVER really tells you when to release the tension from the jack.
Im assuming when the top Strut nut is on, that's when you can release it, true?
RC
RC
release the tension once you take the top strut nut off then just let it down slow and you can pull down on the strut to get it out of the tower, dont worry about the spring, it's not coming out, you would have to try to make it come out.
I found that out when I accidentally lowered the jack just beyond tenision. Nothing happened :nice: I was able to manipulate everything on and off by pressing down on the strut within the underside of the tower.
UPDATE: It's taken longer than it should, b/c Im painting the area under the plates...since the plates are slightly raised, you can see a bit under them...
While the paint dries, Im buffing out my PBR calipers, doing some other work, eating lunch, and watching J. Roberts get APPROVED for Chief Justice :banana:
Right now, Im letting the driver's side dry for about 30 minutes.
One other thing: can the relative height of the strut nut "just" be close to the previous height (using different spacers)? I tightened the first one down...it's about 1/8" lower than with the Steeda plates, but still a good 3-4 threads coming through.
Thanks
RC
Thanks
RC
Not sure what you're asking, but I have about 1/2" of threads above the strut nuts on mine. This was with a spacer on them too. I don't know if that helps. :shrug:
Wystang....too late, however it is pretty much the same as the instructions I have so not a biggie...thanks for the help.
Juiced: I set a level over the fender with the bubble in the middle, then dropped a tape measure down to the top of the strut shaft. With the Steedas on, just over 3" distance from the top of the level to the top of the strut. With the MM's it's just UNDER 3", meaning the top of the strut is slightly higher.
The only prob was that I could NOT slide that dust cover over the bump stop. I had to cut to notches about 3 inches apart to open up the cover to slide it over.. I then took some electric tape, and wrapped it around tight before securring it with the tie wrap.
I will take it to for an alignment, but for now, I just placed a level against the rotor, and moved the plates around until the bubble was in the middle....I guess that's about as good as I can get it by eye.
Hope it doesnt fall apart on the way to the shop. :nono:
RC
RC
thats pretty much what you have to do, it will hold up :nice:
WhiteDevil said:
For mine i used one big spacer on the underside of the plate and the two small ones and one big one on top of the CC plate. I still seemed to have a good amount room left with the hood.
WOW...I just used one 1/4" one under the bottom plate (right on top of the tower) and one 3/8" spacer under the top nut....THe Steeda plates had a 3/8 and a 1/4" one on top, but the plates sat flush down against the strut tower.
RC
it would be more likely to come out if it was a 2" lowering spring, wouldn't it?
this is good info, mine just came in today.
NOW, I can help you. :lol: (no..the springs are not that tight, like stockers)
BIG PROBLEM (well fixable)..I forgot the spacer on the bottom...Put everything back together, lowered the car, and BAM!!!...Strut shaft came right up through the tower :nonono: :rlaugh: I called MM for verification.
They recommend the larger spacer on the bottom, and the other 3 on top:
2 small, 1 large... the shaft is way high, but it still clears the hood. They said the higher the better so long as it clears....Just finished cleaning up...what a long a$$ day.
Ill put pics up in a different thread later.
RC
