  • SN95 4.6L Mustang Tech
Quick Mach 460 head unit question
  • Thread starter Thread starter Miller220
  • Start date Start date Jan 19, 2010
Miller220
36
  • Jan 19, 2010
Is it possible to still use the amps but use the auxillary plugs for my iPod? I'd be swapping the 460 hu for an older alpine headunit. I ask this because the back of the Alpine HU has the red and white connections and if I can save $500 by just going and getting a $10 cable, I wouldnt complain at all.
patman0911
2,287
Tuscaloosa, AL
Jan 20, 2010
  • Jan 20, 2010
What auxiliary plugs are you talking about?
Is there an aux input built into 2002 Mustangs that you want to tie into? If so, is it somewhere on the dash or console, or is it on the face of the factory radio?
Or, do you just mean the Alpine has an aux input?
Either way, the Alpine needs to have an aux input and if it does then it should play through the system just like the radio or CD does.
Miller220
36
  • Jan 22, 2010
I meant the alpine has the aux, because my 460 HU is bad, I wanna tear it apart and get whatever cd's are inside of it. I guess my problem is, I was worried about not being able to use my amps if I Plug the Aux cable into Alpine HU as opposed to the 6 disk changer.
patman0911
2,287
Tuscaloosa, AL
Jan 22, 2010
  • Jan 22, 2010
Unless I'm missing something, I don't see why it wouldn't behave just like any other source as far as the Alpine is concerned.
The Alpine has an auxillary line input - either RCA plugs or a 1/8" jack somewhere on it - and the aux input is one of the selectable sources to play from, right? If you've installed the Alpine HU correctly so that its CD and radio plays through the factory amps and speakers, then the aux should too
Miller220
36
  • Jan 22, 2010
Ok thanks, I was just checking, making sure that there isnt something I should know about that I dont. Like I said in threads prior...I'm an idiot when it comes to cars. Thanks for the help though!
Run a 5 channel or use head unit and mono amp for sub?
  • 2000xp8
  • Sep 20, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 23, 2024
2000xp8
L
2003 New Edge Mach 460 question.
  • LightSkinMocha
  • Jul 6, 2023
2K
1996 - 2004 SN95 Mustang -General/Talk- Jul 27, 2023
Ranger
Can a Ford OEM 07 mach mp3 head unit be adapted to. 99 OEM mach 460 system ?
  • Blackrayn09
  • Aug 9, 2022
  • Mustang Sound & Shine All
Mustang Sound & Shine All Aug 9, 2022
Blackrayn09
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
Fuel Fuel Pump Rewire, New Fuel Lines, and Installation of New Fuel Pump Hanger with AN6 Connections
  • AeroCoupe
  • Mar 12, 2023
13K
Fox 5.0 Mustang Tech Apr 16, 2023
AeroCoupe
