  • SN95 4.6L Mustang Tech
quick NOS question
  • Thread starter Thread starter chef_333
  • Start date Start date Feb 16, 2004
C
chef_333
140
Bay Area
Feb 16, 2004
  • Feb 16, 2004
Hello Guys,
Real quick when putting in NOS system, with the WOT under the gas pedel, how do you inform the car's computer that you are running NOS? I mean after arming the system how does the car know when the NOS is running or not running? How does the car know to retard timing? I bought a used Nitrious system off a guy who ran it on his mustang but it doens't look like the system comes with a computer brain to tell the car what to do. Any help would be great.
lopey4.6
20+ Year Stangneter
Jan 4, 2004
309
Westlake,OH
Feb 16, 2004
  • Feb 16, 2004
What year is your car? Do you have a wet or dry kit?
C
chef_333
140
Bay Area
Feb 16, 2004
  • Feb 16, 2004
!996 is the car year, and it is a wet kit. I have installed a larger fuel pump in the tank to handle the extra load (have a bunch of other mods) but still not sure how the car supposed to know the difference from being armed? and receiving juice?
xomp
91
SOCAL
Feb 16, 2004
  • Feb 16, 2004
i always thought for all the nitrous systems they just put it in, and the rest depends on the computer reading the a/f ratio from the exhaust and correcting based on that.
most kits just come with a lot of safety switches on the solenoids so you wont break something.
i run a ghetto nitrous system with only venom bottle, nos solenoid/lines, and just push the button.
i looked at a NOS diagram for their kits, and the only other thing they had was another solenoid to cut off the nitrous if there was something wrong with the fuel supply (forget, it was fuel pressure or something?)
C
chef_333
140
Bay Area
Feb 17, 2004
  • Feb 17, 2004
Well,
I am not sure. It seems ot me you need to retard timing somehow, or something. Can nitrious really be runned without the car really knowing about it?
chini42
138
Brownstown, Michigan
Feb 17, 2004
  • Feb 17, 2004
Under wot, the computer is not reading off of the O2 sensors anymore, its going off of tables. Im pretty sure that a wet kit should be adding fuel as well as nitrous into the intake when its activated, and a dry kit needs a chip.
2kyellowgt
224
Nanuet, NY
Feb 17, 2004
  • Feb 17, 2004
Here's one quick semi related question for you guys. I am going to be installing a NX wet kit can I use the stock intake set up or should I get a CAI.
lopey4.6
20+ Year Stangneter
Jan 4, 2004
309
Westlake,OH
Feb 17, 2004
  • Feb 17, 2004
With a wet kit timing is not retarded, and the extra fuel is added to avoid a lean condition. I suggest you take your chip out because a POS Jet chip advances timing and you'll blow your engine. With your setup I would suggest getting to a tuner and getting a flip chip. With that you can have a N/A setting and a nitrous setting with reduced timing.
You can use the stock intake.
N
New Edge 3.8L Forged Internals
  • NtheGAME
  • Jun 1, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jun 3, 2025
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
Preparation for Holley Terminator X install – Foxbody 306 (electrical fan, alternator, MSD Ignition, etc)
  • So_Flo
  • Mar 1, 2026
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
General karthief
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
